Hello Rysiek,
We regret for the inconvenience caused. Please check whether you have installed any other conflicting applications like McAfee, Avast, Norton etc… on your PC, If so please uninstall the conflicting applications.
If not, please follow the instructions on the article http://support.avg.com/SupportArticleView?urlname=How-to-reinstall-AVG to reinstall all the traces of the AVG program and check whether it resolves the issue.
Hi i have problem with 0x80010299 error. bought one year licence for avg zen and i can't make an actualisation of avg internet security. should i reinstall avg ? or someone can help me manual with this problem ?
Rysiek, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Rysiek,
