Hello Alexandre,
We understand how something like this will try your patience.
Mostly this error is occur due to anyother Antivirus program or previously installed AVG on your system.
Is there any other Antivirus program or AVG program installed on your system?
May I know the name of the AVG program you wish to install?
0xC0070643: Event exec_finished - How to fix this problem? Install or Uninstall does not work.
Hello Alexandre,
