0xe001003d error 'fix' instructions for 2014, need updated
Hello Ronald. I kindly request you to follow the instructions sent to your email to install the AVG program on your PC. Thank you.
Following your 'fix' instructions which says to delete registry files labeled 'AVG 2014' under HKEY_LOCAL_MACHINE>software>AVG, I only have a file labeled ZEN [no 'invalid control file' logged under the Zen folder however].  To repeat this in 'step 4' in fix instructions, my HKEY_LOCAL_MACHINE>software>wow6432.node>AVG folder does have a 'AVG 2015'  (not avg 2014, the fix instructs need updating for 2015) folder that 'does' have the 'invalid control file' logged under it.  But there's also an AWL2015 folder [no invalid control there…but a lot of instructions for PC Tuneup [paid] ].  This is a problem dating back years, and instructions need updating for 2015 Zen products.  What do I delete 'specifically'.  Thank you.
