Hello Lynne. The PC TuneUp only suggests you to remove items based on the settings that best suits your system. I request you to proceed with what the software suggests you to keep your system at its best settings possible. Thank you.
Hello Tobi. Thank you for your trust on AVG. I certainly understand your concern. I guess some settings would have changed after the update and that is the reason there should be some difference on your results. Moreover the usage on Internet also relates to these results. If you are browsing more on the Internet it would find more files and if your usage becomes less then the number of files will be less. If you feel that there are same settings and same internet usage then please do let us know. Thank you.
I have had AVG 1 Click Maintenance for about nine months and it seems to help keep my computer free of debris. It used to show that it was removing dozens, if not hundreds, of items from "browser" but after an update last week it refers only to maybe a dozen or a couple of dozen items to remove. I assume it was clearing my cache and my history, my Internet use hasn't changed, and I am wondering what made the difference? Thanks.
I ALWAYS do what AVG PC TuneUp tells me. If it says "delete" I do so because I trust AVG completely. But you did not answer my question, which is why, BEFORE the update, it always identified dozens if not hundreds of browser-related items to delete but after the update it identified less than two dozen. Then, yesterday, it identified a couple hundred. Has AVG changed the definition of "problem?" Or has Google Chrome and/or Yahoo gotten sneaky, trying to sneak naughty bits past my AVG software?
