Hi Lior,
In order to analyze it please provide us with diagnostic output (gather it right after inducing issue) using this tool and please add detailed description of issue.
1 Click maintenance - clean Registry, indicates (in red): 2 problems found. It looks like "Run maintenance" do fix the problems, but when I try to see if they are gone forever the same problems appear endlessly… The problems details are:
1. HTML Document, key references the missing CLSID "HKEY_CLASSES_ROOT\CLSID{8895B1C6-B41F-4C1C-A562-0D564250836F}".
2. MHTML Document, key references the missing CLSID "HKEY_CLASSES_ROOT\CLSID{8895B1C6-B41F-4C1C-A562-0D564250836F}".
Please comment or help, Thank you
Hi Lior,
