1 click maintenance
Hi Joe, I will help you with the issue ,
please open the AVG PC TuneUp and then click settings in Maintenance tab
and check if all options are checked.
Please let us know and we will solve the issue
Thank you
I run the "1-click" quite often and it will NOT delete 'temporary installation files' even though they are checked for deletion. There are 14,831 files.
Hello Joe, for your information the important system files cannot be deleted by AVG PC TuneUp and it should not be deleted. If it is deleted your system won't function. The number of files that aren't deleted are only the system files. Thank you.
ALL options are checked. I also googled my problem and found an answer that stated it was a file for 'Windows 10' that was automatically downloaded by Microsoft. I have NOT installed Windows10. The files all start with:
C:$Windows.~BT\Sources\SafeOS\SafeOS
