"1 Hard disk heavily fragmented" reported in 1-Click Maintenance
Hello Jean.
Thank you for contacting us. I would like to inform you that the disk defragmentation will take several hours based on your hard disk size. So I would request you to run it when you are not using your PC. Please, feel free to let me know if you require any further assistance. Thank you.
I am using AVG PC TuneUp 2015 on my PC running Windows 7. I frequently get the message "1 hard disk heavily fragmented" after performing a maintenance. When trying to fix the issue via the "1-click Maintenance" software, the "defragmentation" starts but never finishes. The only option I have is to abort the operation. Is this because the hard disk is actually not (never) fragmented? Why do I get this notification if there is really no problem to be solved?
Hello Jean.
