A program will not work after adding tune up
Hello,
Please try to restore changes made by AVG PC TuneUp on your computer to narrow down if the issue is caused by AVG TuneUp.
1. Open AVG PC TuneUp program.
2. Click on the Rescue Center on the right bottom corner.
3. Click on Undo Changes.
4. Select and restore the changes made by the AVG PC TuneUp program.
If you have any anti virus or firewall program installed, please disable it also and check if that resolves the issue.
I have photosync and it worked fine until I installed the tune up program.  I cannot download any pictures from my iphone to my pc.
Hello,
