About using vpn and load internet speed slowly
Greetings,
We regret the inconvenience caused.
The slowness with internet speed with VPN turned on is an expected behavior.
This is because VPN encrypts traffic and data before sending it to a server.
Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
You can change the location in AVG Secure VPN and check whether you could see a change in internet speed.
https://support.avg.com/SupportArticleView?urlname=Use-AVG-Secure-VPN
Greetings,
I have using vpn for 3 computer pc , but all the loading web page is very slowly.
