Activate avgfree help
Hello Shelly,
We understand that you wish to confirm whether the AVG Protection free that is installed on your computer is fully active and working fine.
Please open the dashboard of AVG Protection free and check whether all the components are active and the message should say as "You are protected".
From this you can confirm that the AVG program is working perfectly and protecting your PC completely.
I have been using Avgfree for over 15 years. I have windows 10 defender running on HP proseries laptop. I need help making sure avgfree is working and activated on my computer. thanks
Hello Shelly,
