Advanced scan stuck at 69%
Hi Marcel.
We're here to help.
When the progress reaches 60%, please check the file that is being scanned.
If the file being scanned keep changing, the scan is running but slow. If the file being scanned is same for long time, then we can conclude that the scan has stuck.
I have AVG installed. When I run a scan the first steps finish quickly. The step "Scanning for advanced threats…" runs till 60% and then stays that forever (days).
I already used avgclear.exe to remove and then re-install but the result is the same.stuck at 60%
What can I do more?
Hi Marcel.
We're here to help.
