Advanced Settings
Hello Dot,
I will help you with the necessary information.
The settings you have mentioned is for an older version of AVG Internet Security.
Please disable AVG temporarily on your computer and check if you are able to access Dashlane without any problem.
To disable AVG temporarily, please right click on the AVG icon present at the bottom right corner of your desktop(System Tray) and use the scroll bar to "Disable Protection".
How do I find 'advanced settings' to enable linkScanner Surf-Shield settings?   For some reason my Dashlane program doesn't work like it should and it was suggested to turn off the above setting.
Help needed please.
Dot
Hello Dot,
