Advanced trader pro. program keeps closing (IDP.Generic)
Hello,
Been using advanced trader Pro program for several years and AVG free and today AVG found a threat and keeps closing the program, I updated AVG and I did a deep scan
Threat name : IDP.Generic    AVG shows as  " We've blocked CefSharp.BrowserSubprocess.exe because it was infected with IDP.Generic"   Currently in quarantine file and don't know if i can add an exception or could this be a real virus?
Thank you
Steve
Hello steve,
We apologize for the trouble caused. We'll check and help you out.
Please share a screenshot of the threat pop up by expanding the "See details" present in it, so that we can check and assist you accordingly.
Refer this article for creating one -
https://support.avg.com/SupportArticleView?urlname=avg-create-screenshot
You can post the screenshot here in your topic. Click on Answer & then click on the Image [mountain symbol] & follow the instructions
Awaiting your response.
Thank you for your efforts, steve.
Since you've mentioned this is a known site that's being detected as threat by AVG. It could be a false positive, hence please use the below link to submit a false positive form, so that our developers will check and whitelist the site (if found harmless)
https://www.avg.com/false-positive-file-form
In the meantime, you can refer the below article to add the site in exceptions list and use it.
> (https://support.avg.com/SupportArticleView?l=en&urlName=avg-antivirus-scan-exclusions&q=adding+to+exceptions&supportType=home)
Thank you for understanding.
IDP.Generic
ScreenShot of the issue
