After running AVG shows problems
Hello Richard,
For your information, In the AVG Antivirus dashboard we have an option called "FIX PERFORMANCE". When you click on this Fix performance you will get a PC Analyzer window opened which will analyze your PC and will display the result of your PC errors but to fix those issues you have to purchase the license for AVG PC TuneUp and install it. The aim of this Fix Performance is to know about our AVG PC TuneUp features and functions.
As per our record you have purchased the license only for AVG Antivirus program which gives protection to your PC against viruses and threats. AVG PC Tuneup will only enhance your system performance for which you have to purchase the license for it and install it.  Thank you.
Hello Richard,
After running AVG checkup screen shows errors but will not fix them without a purchase of the Tune Up. What did I pay 59.95 for ?
