Hello Bruce,
We are sorry to hear that, we suggest you to remove the AVG traces completely and start a fresh installation. Please run AVG Clear tool and AVG Remover tool to remove AVG and its traces, please use the following instructions
1 Use the link https://share.avg.com/steam/PSP/AVG2017/AVG_Clear.exe to run the AVG Clear tool.
2 Open the AVG Clear tool, click Yes in the User Account control dialog.
3 Click No in the Windows safe mode dialog.
4 Select the installed version of AVG, click Uninstall, then click Restart computer. (1/2)
After widows 10 updated, AVG will not open tried to uninstall and reinstall got an error code 0xa0010004
Please run the AVG Remover tool by using the below instructions.
1 Download the AVG remover tool please click on this link:
2 Run the downloaded tool and follow the instructions displayed on your screen.
3 Your computer will be restarted automatically.
After reboot, Open C drive and look for folder "AVG Remover" and delete it manually, also delete "AVG" folder in "Program files (x86)" in C Drive.
Click on the link to install your AVG Internet Security - Unlimited : http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-Protection
Please let us know if you need any further assistance. Thank you.
Hello Bruce,
