Alarm clock extreme not working correctly
I was very happy with Alarm Clock Extreme but in recent weeks after some update, it's no longer working correctly.
  • It does not shut off automatically even though I have a 30 second snooze timeout.
  • It doesn't show on my phone while the alarm is ringing. I have to open the app to dismiss the alarm.
  • I've tried re-installing the app and setting up a new alarm but the problems persist.
Hello Jake,
Thank you for contacting AVG Community support.
We're glad to help pointing you in the right direction.
We do have a specialized team who deals with mobile queries.
In this regard, we'd suggest you to raise a request to them via this link (https://support.avg.com/support_contact_form?l=en&retUrl=support_Android_AVG_Antivirus).
Note : You may need to choose 'yes' for the 1st question that is in the above link to request answer via email.
Select the product to be Alarm clock extreme.
Hello Jake,
