Android AVG pro problem
Hello Clay,
I understand how difficult this is for you. To best assist you with this, I suggest you to contact our Mobile support. Please click on this link http://support.avg.com/SupportArticleView?urlname=How-to-contact-support-through-the-Mobile-Contact-Form for the steps to contact our Mobile support.
Hi, I tried the AVG Android virus protection and got annoyed by the ads. Easier to upgrade than delete so I did.
Since upgrade my Android 4.4 Asus padfone 2 very frequently shows message " Unfortunately, the process android.process.acore has stopped.
This displays VERY frequently, and is super annoying.
Any suggestions how to fix the problem?
Thanks, Clay
Hello Clay,
