Android Battery Monitoring - How to Disable
Hi Joseph,
We're glad to help pointing you in the right direction. We do have a specialized team who deals with mobile queries.
In this regard, we'd suggest you to raise a request to them via this link.
Note : You may need to choose 'yes' for the 1st question that is in the above link to request answer via email.
How do you disable the Battery Monitoring app from the AVG Suite. Every time I do a fresh install of AVG, the Battery Monitoring app is sitting there running in the background.
How do you disable it?
Hi Joseph,
