Annoying Get longer battery life notification
Hi Luke,
I am sorry that you receive incorrect notice about battery.
Please let us know, if you getting the notice on the AVG Interface.
You can post the screenshot of the message here in your topic. Click on "Answer" & then click on the "Image" [mountain symbol] & follow the instructions.
Hi, I do have Tuneup installed and its version:16.80.3.38236.
Cleaning definitions version: 1603
AVG Framework version: 1.227.3.31392
Hi Luke,
Hi, i've now uninstalled PC Tuneup and I'm no longer getting the pop up messages. Thanks for all your help!
Luke
Hi, I keep getting the 'Get longer battery life' notification pop up on my laptop while I'm running off the mains supply. I've emailed the AVG Support but havent had a reply.
Any ideas how to stop this popping up every few minutes?
Thank you for providing us the info, Luke.
Would you be so kind to either share us the screenshot or snapshot of the pop up that you receive for better clarity?
Also, let us know if AVG PC TuneUp is installed on your computer. If installed, help us with the version of it. To check the version : Open AVG - Menu - About or Open AVG - Help - About.
If you find that it is complicated, you can share us the screenshot of the TuneUp interface (page that you get after opening program), which will help us to identify the version of it.
Regarding your previous writings, we're unable to find it under your account. You might have used a different email address to raise a request or replied to an automated email system.
Hi, thanks for getting back to me. What do you mean by Avg interface?
The box pops up at the bottom of the screen on the right.
Luke
Glad, we are able to help you, Luke.
Luke
