Annoying Pop-up for expired trial of Pro
Hello Cj,
If you have installed our trial version of AVG Internet Security then after the expiry it will show only the popup to purchase the license to continue with the subscription.
If you wish to have only the free AVG antivirus then you can downgrade the trial to free version by following the instructions mentioned in this link: http://avgread.me/1073t3Z .
If this doesn't help then please use our AVG remover tool to completely remove all traces of AVG program and install AVG free antivirus.
1) To download the AVG remover tool please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
I have AVG Free and I am not interested in continuing the free trial of the Pro version that I downloaded two months ago.  How do I get rid of the annoying pop-up asking me to buy the Pro vesrion?.  This pop-up is disabling the main interface to the free version so that I cannot access any of the scan reports that are being done on my computer through the free version of AVG.  Do I have to uninstall all AVG products and reinstall AVG free?  I do not see any other way to get rid of this annoying message.
Hello Cj,
  1. Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
    To download our AVG free antivirus program please use the below link:
    For 32 bit: http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x86_694.exe
    For 64 bit: http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x64_693.exe
