AntiTrack problems
Hello William,
We are really sorry to know that after few updates, AVG AntiTrack is blocking internet and AVG Secure VPN changes each time. Please apologize for the inconvenience caused. We'll certainly check and help you out.
We regret to inform you that this is not an expected behavior of AVG and AVG AntiTrack will not block internet of AVG Secure VPN.
In this regard, we would request you to check whether kill switch is enabled.
When Kill Switch is enabled, your internet connection is automatically blocked if AVG Secure VPN unexpectedly disconnects. This ensures that your real location is not exposed.
You can activate Kill Switch via ☰ Menu ▸ Settings ▸ Network Security. Tick the box next to Activate Kill Switch.
Also, please try change your location and protocol and check with the issue.
Refer this article to know more: | AVG (https://support.avg.com/SupportArticleView?l=en&urlName=troubleshoot-avg-secure-vpn-connection&q=Troubleshooting+when+unable+to+establish+or+maintain+a+VPN+connection&supportType=home)
If you are still facing any issue, please let us know and we'd be happy to assist you.
Hello William,
For a few updates, anti-track was locking me off the internet for several hours each time the VPN changed.  Now it is restarting my system each time the VPN changes.  What's up? Feels like the updates are not being tested.
