Hi Alyce,
You can try reverting the changes made by Driver Updater by following the below steps :
Open Driver Updater - Restore (at top) - Select the Audio driver - Restore & restart the computer to check if it helps.
You can follow the same steps to restoring the drivers required to access your camera.
Currently, we're operating with limited staffs due to Covid 19 pandemic. Hence, the phone support is unavailable.
Camera not working. Advised to update drivers. Did including Reltech and now neither audio nor camera work.
Where the hell is a phone humber where I can talk to someone with a good connection and speaks English understandibly?
Hi Alyce,
Driver updater doesn't open. Just reverts back to "Protected."
