Auto maintenance won't turn off
Good Day
I have this same problem. Did the uninstall and re-install fix the problem?
Hi Leland,
This isn't the expected behavior. Please accept apologies for the inconvenience caused.
We request you to uninstall the AVG PC TuneUp and reinstall it again.
Then try to turn off the maintenance again.
Keep us posted.
I go into PC Tune Up>menu>settings>auto maintenance and turn off auto maintenance. Auto maintenance stays turned on and drains resources by scanning ,etc., while I'm trying to work on the computer. The icon in Tune Up home page says it's turned on. How do you turn off auto maintenance in PC tune up?
I regret for the experience, Leland.
However, we suggest you to reinstall the program and monitor the status.
I have sent an email with the steps to uninstall, install and activate AVG TuneUp.
Please check the email and reply back for further assistance.
Great to know that the issue has been fixed, Lee.
I highly appreciate you effort and time in resolving this.
Hi Leland,
Keep us posted.
Good Day
Uninstall/reinstall fixed the problem. Today, I would try Menu>Settings>Troubleshooting>REPAIR APP first before performing uninstall/reinstall. BTW, I just received an email today notifying me of your December 13, 2019 post.
