In the System status window I also see "Automatic Maintenance is currently not set up as recommended". Not sure what that means, I didn't change anything. I attach my settings.
Also note that "Automatic Maintenance completed 22 hours ago" but the "not run in 14 days…" message is still there.
Hello Alexandros. I would request you to share you product feedback here http://avgclick.me/AVGfeedback so that it will reach the correct person and your suggestion will be taken care of. I appreciate you taking time to provide your valuable feedback. Thank you.
Hello, using AVG PC TuneUp 2015 and I get the above warning fairly often. However, I have set in the options to run Automatic Maintenance "after 14 days of PC usage" so it is quite normal for the AM to not have ran in 14 days. So, my suggestion is to raise the day limit after which this warning is shown. For example, make it +10 days of whatever option the user has set.
I can understand your question Alexandros. The user can setup the schedule for automatic maintenance but in the background it always runs and it will analyze your PC. That is the reason it prompts you to run the maintenance. You can ignore it but it cannot be stopped completely.
Hello Alexandros. Please open AVG PC Tuneup–>Settings–>1-click maintenance and check if it reports any warnings next to the items and fix them. If you do not see any warnings, please follow these steps to send us diagnostic information from your computer. This information will allow us to analyze the situation and provide you with solution:
Click this link http://www.avg.com/filedir/util/AVG_SysInfo.exe to download the AVG SysInfo tool.
Run the downloaded tool.
Click Accept to confirm the license agreement, and then click Continue.
Once the screen Output created is shown, fill in any additional details, and click Attach to attach this folder " C:\Users</a><USER NAME>\AppData\Roaming\AVG\AWL2015".
Click Send, fill in your email address, and then click Send again.
We will analyze the received files and provide you with further information.
