Avg 1 click maintenance gets stuck
Andrew,
Sorry for the inconvenience caused. In this case, make sure that your AVG PC Tuneup has the latest version of 2016 and repair avgclick.me/RepairAVG your PC Tuneup program. Check for the issue and if the issue persists, please do let us know so that we could check with that and assist you further. Thank you!
Hi , AVG 1 click maintenance starts running OK, but then always gets stuck on " clean up windows & maintenance ".  After an hour or so I give up and press cancel.  Do I need it anyway, or should I try and sort out the problem…and how ?  I am not extremely computer literate so any  fairly simple help would be much appreciated. Thanks.
Andrew,
