Hello Omur. I am sorry to hear that you are facing the issues with the AVG 1-Click Maintenance. I kindly request you to have a look at this article http://avgread.me/1BlmDPv to continue with the scanning using the 1- Click maintenance. Thank you.
Hello Alex,
I removed Defragment Registry from 1-Click Maintenance as you did and the problem went away.![]()
I agree with you on that Defragment Registry is included in 1-Click Maintenance. I believe there is a
solution for this issue. Thank you.
Best Regards
Hello,
AVG 1-Click Maintenance stops responding while analyzing defragment registry (USER_2). I would appreciate if you could kindly let me know if you could help me on this issue.
Regards.
Hello,
Thank you for your immediate reply. I checked the article you suggested and followed the instructions.
I checked to see if there is any update but I'm already using the latest version. So, reinstalled AVG PC TuneUp once again as a last resort. Unfortunately, the problem still persist and ended up with no luck.
Good Morning,
Thank you for your kind reply. I'm sending the screen-shot
along with this message. 1-Click Maintenance is still
analyzing Defragment Registry as I write this message.
I hope the screen-shot would be helpful to detect this
issue.
Regards
Omur Saygin
Hello Alex,
Best Regards
