Curtis, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Curtis,
During the antivirus scan most of the system CPU usage will be used and it is not recommended to use the PC at the time of Antivirus scan. Also there are chances of slowness in PC Performance during the scanning.
We request you to perform repair of AVG Protection program once as mentioned in this article: http://avgread.me/1BVxDSY and check whether the issue persists.
I've been using AVG ever since it was just a free product and just had AVG antivirus. But lately ever since we got AVG Zen and AVG 2017 I've run into a few problems.
First of all, when your in the AVG 2017 and AVG Zen control panel it take so long to open the antivirus part of the software. It take more than 5 minute to open up Antivirus part.
Second, is there a way for me to disable automatic scans after an update? The update are fine but when the scan begins it slows down my computer to the point I can do my work. I need the computer to perform at it best when I'm working.
Third, I think there is a problem with the updates. This morning when I updated my virus definition, the setting automatically set itself back to "Automatic Update" when I set it to "Ask when an update is available". The only reason I did this was because of the above two problems.
So technically speaking all these three problems are related.
Thank you for reading this. Thx.
Hello Curtis,
