AVG alert after closing MS Edge
Hi Ian,
We are sorry to know this.
We will check and help you with this issue.
Could you please share us the screenshot of AVG pop-up message about Microsoft Edge browser trying to access your login details in order to understand better and resolve it?
For taking a screenshot, please refer to this article: https://bit.ly/3uPidWV
Also, please confirm whether you are facing this issue in AVG AntiVirus Free version or paid version.
If paid, please mention the name of that AVG program.
Are you getting any error message while trying to contact our AVG support?
All of a sudden I have started getting the following message from AVG.
msedge.exe is trying to access your login info in Edge.
this info includes your username and password
what would you like to do
BLOCK APP OR ALLOW APP
What is happening.? I cannot contact AVG support because they are busy unoriving customer support.
Any idea as to what I should do? Should I BLOCK or should I ALLOW?
Thanks.
Hi Ian,
Unfortunately it makes no difference. The alert still keeps coming up after just opening and then closing MS Edge.
The strange thing is that I can have Edge open and there is no alert. The alert comes up only after closing Edge.
Hello Ian,
Thank you for sharing the screenshot. Could you please reset the Edge browser once and check the status?
Refer the following article to know how to reset the browser. Keep us updated.
Here is the screenshot with the message. Basically, I only have to open MS Edge and then close it and this will pop up
User-added image
