AVG alerts are not on top, driving me crazy
Using internet security from AVG, just on a week now and keep changing my mind whether to refund or not. I had decided to keep it, but for example, if I visit a webpage that is blocked, if I didn’t have sound notifications on, I would not know what happened. The AVG notification box that opens in taskbar (not the one that opens on bottom right of screen, those work properly, but the explorer window type ones that you can move around) sits underneath edge and I can click on the notification in the taskbar 1000 times and it will just not display till I close Edge. This is the first AV product in the history of my computer using life (43 years of it now since C64 days) I have seen an AV product not display its important threat notifications on top of other windows. It’s driving me crazy, and despite the false positives I have had, despite other issues, I like the program a lot but THIS will be what makes me ask for a refund. It’s untenable. If there’s an emergency notification, you should be able to instantly see it, PERIOD. Any advice?
