Hamish,
We would request you to run AVG remover tool to completely remove AVG and then re install it to check whether the issue is resolved.
Please click this link http://download.avg.com/filedir/util/AVG_Remover.exe to download and "Run" the AVG Remover tool.
Unfortunately it still won't work, but thanks for your help
Hello Hamish,
We don't think AVG is causing this issue to the Edge browser.
We request you to disable AVG program temporarily by following the instructions mentioned in this link: http://avgread.me/1GnMD3N and check for the issue with Edge browser and do let us know the status of it.
Hi, I have AVG installed on my school computer. At home everything works well, but on the school network, any internet link produces a page saying either "There is a problem connecting securely to this website", or "There’s a problem with this website’s security certificate" - even Google! Is there anything that I could do?
Hello Hamish,
I disabled AVG at school for five minutes and was able to open links without receiving errors. The IT guys at school said something about there being a different security software on school computers (I bought this computer externally though?). Could this be messing with the program
Hello Hamish,
We regret for the inconvenience caused. Please try to repair the AVG program and check whether it resolves the issue. Please follow the instructions on the article avgclick.me/RepairAVG to repair the AVG program.
