AVG and Internet and Wireless Hit
Hello Mary. Sorry to hear that. For your internet issue please try the steps mentioned in this link: http://bit.ly/1Fqdu9a. Were you able to uninstall your AVG program from the control panel or do you get any error message while trying to uninstall it?  I would recommend you to start with uninstalling of all unknown/unused programs and browser addons.
HELP
Earlier this week, something happened (I was on American Airlines website and was hit with Adware.  Then I had problems with the net adapter and has to be reset.    Now, it says my AVG is up to date, but it can't connect to the internet and if it checks everyday something is wrong.  I use firefox (and rarely) ie.  It loads the web page but I cant go anywhere or do anything.
I found my AVG program folder in an odd place and shows $AVG.  One threat is serious but is in C:/$Recycle.bin and 3 other threats were not removed by the program when the >>>> hit the fan
I cannot access C:/$Recycle.bin to delete the file or should I just download a fresh version of AVG and firefox?  Will this work?
Also, the home network is now only showing my computer and the printer.  The TV and other active connections do not show up as part of the network,  but they still work.
Can anyone help me?
