AVG and other products not appearing in the system tay
Hello Philip,
We are sorry to know that the system tray icon of AVG does not appear in your computer. This can happen due to an incorrect update. We suggest you to run the AVG updates and see if that fix the issue. If the issue persists, please run the AVG repair avgclick.me/RepairAVG. Feel free to contact us, if you still have any issue.
Hello Philip,
Thank you - yes the repair option didthe trick also worked on a fiends PC - Philip
I have noticed on AVG forums that the AVG icon no longer appears in the system tray. The AVG console starts up fine and says you are protected.
I can confirm I am seeing the same issue with the system tray. Although I have an SSD drive and Windows 7 with Glary utilities reporting an average start up time (there is noway my PC would be usable under Windows 10 and I have refused the free upgrade), what concerns me is that despite re-installation -  AVG does not appear - but the same is absolutely same is true of Serviio a DLNA media server. The console starts fine and will re-catalogue my library and says the server is running - but is not, I can see  this on other devices. There has been a recent Windows 7 update that has caused issues. Whilst I realise Servio is absolutely nothing to do with AVG you are hitting the same issues. I will write to the Serviio Team tomorrow pretty much in the same context. There may and I stress may be some start up time issues - I am highly technically competent and will assist with any files you require.
Philip,
Pleased to see that you appear to be now sorted. Thanks for returning to the Community & posting. We appreciate your efforts and patience. Please feel free to get back to us for any issues with AVG. We work around the clock, thank you.
