AVG and System Restote Points
Hello Gerry,
Unfortunately, from your post, it was not clear to us how we can help you.
Could you please specify your request and provide us with more details?
Do your comments regarding AVG PC TuneUp apply equally top AVG Zen?
Can you uninstall or disable AVG Zen whilst continuing to run other AVG software?
Removal of Windows System restore points. This didn't occur. Does it now?
Hello Gerry,
Hello Gerry,
Thank you for the clarifying the issue.
Our AVG Antivirus will not delete or doesn't have the option to delete the Windows System Restore Points whereas our AVG PC TuneUp program has the option for doing it but it won't do it automatically.
On the scanning of System cache and files on AVG PC TuneUp it will show a window with many of the options, one of it will be the delete system restore points and it will have the "check box" to tick. If you have ticked the option and proceeded with the clean progress then the restore points will be cleared.
Are you using the trial version of AVG PC TuneUp?
