Hi Richard,
We will help you to sort out the issue.
Let us disable the AVG and check for the issue again https://support.avg.com/SupportArticleView?urlname=Disable-AVG-Antivirus
Keep us posted.
I use an X-Rite i1 Studio monitor calibration system, V1.5.1/XRD Version 3.1.96116 on my Windows 10 pro OS. I have to access my computer services menu to get to X-Rite services management to enable such services. For some reason the X-Rite services are disabled after I calibrate my monitor or exit the application not withstanding I set it to Automatic. The X-Rite service people told AVG might be disabling the X-Rite services and suggested I contact AVG support to see how I can prevent this from happening.
So, is AVG disabling the X-Rite services and if so how do I correct it?
Thankyou for your attention to this matter.
Richard Galosy
rgalosyphoto@gmail.com
Hi Richard,
Keep us posted.
