Hi Paul,
We're glad to look into this & help you. Initially, we appreciate your efforts in researching on the fix.
Please clarify whether there are any other antivirus installed on your computer. If so, please uninstall them & let us know if it helps.
On Anti Track - behind "system privacy" is a button for "Keep what I do on my computer private". This is on when I boot but shortly after it switches off. The message says it was changed externally. How can I find out what is changing it (and stop it happening)?
I think the problem is caused by Microsoft edge (which I do not trust) and I have tried various ways of disabling Edge without luck. All three methods that are listed here - https://silicophilic.com/disable-microsoft-edge/
Hi Paul,
