AVG Anti track filter - very high power usage
@Alessandro, be careful… because the "hotfix" solved the "total connection loss" bug, but… the slow-browsing is still there.
Hello Alessandro,
Our developers are still trying to fix this issue at the earliest.
You will get a notification once the update is released from AVG team.
Starting from last friday, I'm exeperiencing a problem which is blocking my work
Some of web pages are not reachcbale, as wel as gmail and connection using RDP to my internal  host (on private LAN).
All IP are reachable using ping, but most of services are not working.
I verified and as soon as I stop the service "AVG AntiTrackFilter (32 bit)" (I dont' know why a 32 bit executable is running…) everthing works fine…
From task manager I can see it has a very high power use. After killing it, it restart normally and all works fine.
Is someone expereiencing the same problem?
Thank you
Alex
Hello Alessandro,
