Jan-Peter, Mac OS support… Please click on the following link (http://avgclick.me/AVGtechnical) and choose Yes for the Question "Are you currently using any paid/trial AVG products?" inspite of using the Free version and fill out your details, select as Mac OS then the name of AVG Program that you installed in your device and in description please completely explain about your issue and finally click on the 'Start Chat' option. You will start a live, online chat with one of the AVG agents.
unfortunately glimmerblocker seems to interfere with the update process in AVG AntiVirus for Mac. Whenever I disable it updates work just fine. I tried to whitelist the usual suspects including update-mac-av.avg.com but with not effect. Wiresharking shows that the update process is using some sort of binary protocol it tries to send to akamai servers directly. I also found traces of the update-process using an IP address instead of a URL in order to access stuff which makes it impossible to whiltelist.
Is there a way to disable the use of a proxy for this product that I am not aware of? Otherwise has someone found a way to make it work with Glimmerblocker?
Regards,
JP
