HI Ionutz, I sincerely apologize for the difficulties you are currently experiencing. Have you tried to play with your app TibiaMe-Bot after disabling AVG? If not, please use this article to disable AVG and check - http://avgread.me/1BglrNo . Please let us know if you are able to play after disabling AVG.
i will make a video to show you this problem
Hello all,from 1 week ago i got this problem with app tibiame bot cant connect to internet. First i tryed add to exception but stil didnt work,second add in firewall at aplications app to alow it.(it let me play for 1 day,then again cant connect). i tryed dezactivate avg no work i tryed uninstal and worked… Soooo can anyone help meeeeee??? i like Avg so i dnt want uninstal it ![]()
I told u i dezactivated antivirus but cant play… Is ANNOYNG DO SOMETHING… And i wanted to buy this antivirus…Nothing work … Just if i uninstal antivirus and restart pc then work.
Hi Ionutz, I will help you with the issue, could you please provide the complete name of the program ? , the app tibiame appears to be a online MMORPG, you have to add the whole game folder and also other application which are related to this program to AVG Exception list only then the program will work.
I use Avg internet security trial,on windows 7 ultimate 64 bit. So help me mate i like Avg i think is best(actually that i think)antivirus which i used ![]()
Hello Lonutz. I apologize for the inconvenience caused. I have sent you an email with the article regarding the issue. Please follow the instructions. Thank you.
