I have been using AVG Internet security for years. I am running windows 10/11 AVG updated and now I cannot use Chrome or MS edge. I have uninstalled AVG IS and everything works fine. I have downloaded and reinstalled it as per instructions on the AVG site and once I reboot the laptop after AVG has run its first full scan, neither chrome nor edge can access the internet. Windows says to check the firewall. Any sugggestions
Hello David,
We regret the inconvenience this has caused you.
Let's temporarily disable the individual shields/components of your AVG Internet Security one by one and narrow down the component that's causing this issue.
Refer to this article for detailed instructions to temporarily disable the individual shields/components of your AVG Internet Security.
Keep us updated.
Hello David,
Keep us updated.
