AVG Cleaner Battery profiles
Hello David,
We regret for the inconvenience. To confirm are you facing issue with AVG Android product? If so , Please click on the following link ( http://avgclick.me/AVGtechnical ) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. Please select you are using a paid version even it is a free version you are using. The AVG mobile team will reply back to you via email with a resolution.
I'm a bit perplexed as to how the battery profiles are supposed to work. Home profile connects to wifi (specific accounts) and disables bluetooth. Car profile disables wi-fi and enables bluetooth. But how on earth can it switch between the profiles? If I'm in the house and get in the car my wifi is still connected - it can't switch to car profile because bluetooth is not enabled. Similarly if on car profile and I arrive home, how can it switch to home profile when wifi is not connected. Seems to me that disconnecting from wifi or bluetooth should be the trigger for checking whether another profile should become active - even if that means enabling some services temporarily. Is that how it is supposed to work? Even then somewhat annoying as car mode won't kick in until after I get out of wifi range.
How is this supposed to work?
Thanks.
Hello David,
David, Please note that this Community deals mainly with the technical queries regarding AVG Windows products. AVG Android support is provided through email only.
