Hello Wong.
We regret for the inconvenience caused to you in this regard. To help you with this, I would request you to click on the following link: http://bit.ly/1EC8H4H and fill out your details, select the operating system Android then the name of AVG Program that you have installed in your mobile and in description part explain about your issue completely and finally click on Email option. Our AVG mobile team will reply back to you via email with a resolution. Thank you.
Hello,
I accidentally deleted important pdf files while using AVG Cleaner & Battery for the first time. Can you please tell me is there a way I can recover my files. Thank you very much.
Hello Wong.
