Hello Mary,
We are sorry for the delay in response.
We request you to submit your query to our mobile team.
Please click on this link: https://support.avg.com/support_contact_form?l=&retUrl=support_sales .
Select the option as "YES" and the operating system as "ANDROID"
Fill in the details and click on the option "answer via email"
Once your request is submitted you will be getting the prompt answer via email from our mobile team.
My phone shows that AVG Cleaner Pro used 500mb of my mobile data in 3 days. That is 33% of my monthly dataplan. There does not appear to be any settings to limit mobile data usage for the app or to set it to only use wifi. I can't afford that type of usage so had to uninstall. Does anyone know if it is scanning cloud storage? That is the only thing i can think it would be scanning to generate that much data usage.
Hello Mary,
Mary, Please note that this Community deals mainly with the technical queries regarding AVG Windows products. AVG Android support is provided through email only.
