AVG Cleaner using mobile data
Hello Mary,
We request you not to post multiple times for the same issue, you won't obtain an answer to your query faster.
Please refer your other posting via  https://support.avg.com/answers?id=906b0000000Ddoo .
My phone shows that AVG Cleaner Pro used 500mb of my mobile data in 3 days.  That is 33% of my monthly dataplan.  There does not appear to be any settings to limit mobile data usage for the app or to set it to only use wifi.  I can't afford that type of usage so had to uninstall.  Does anyone know if it is scanning cloud storage?  That is the only thing i can think it would be scanning to generate that much data usage.
Hello Mary,
