Perhaps I was unclear about my goals. I don't want to uninstall AVG; I want AVG to work on my computer without making it overheat and crash. Is there a way to get it to stop using so much CPU power? I tried following your instructions to uninstall AVG, then reinstalled it–I'm still having the same problem.
HI Eric,
We regret to hear about the inconvenience caused. We suggest you to remove all the other security software and AVG using the below instructions
1 Use the link https://share.avg.com/steam/PSP/AVG2017/AVG_Clear.exe to run the AVG Clear tool.
2 Open the AVG Clear tool, click Yes in the User Account control dialog.
3 Click No in the Windows safe mode dialog.
4 Select the installed version of AVG, click Uninstall, then click Restart computer.
Please run the AVG Remover tool by using the below instructions.
1 Download the AVG remover tool please click on this link:
2 Run the downloaded tool and follow the instructions displayed on your screen.
3 Your computer will be restarted automatically.
After reboot, Open C drive and look for folder "AVG Remover" and delete it manually, also delete "AVG" folder in "Program files (x86)" in C Drive.
Please let us know if the issue still persists after AVG uninstall. Thank you
I have the free basic version of AVG. I've used AVG since 2011 and it's never caused any major problems. On 31 March AVG updated itself and apparently something drastic changed, because suddenly AVG severely overtaxing my system, causing the computer to rapidly overheat and crash. I restarted the computer several times, but I couldn't run the computer for more than ten minutes without it crashing, and I had to entirely uninstall AVG to render the computer functional again. I tried reinstalling AVG, only to find the same problem. AVG wasn't fighting any other antivirus software on my computer–is there any way to fix this problem?
HI Eric,
