AVG does not seem to be able to deal with an Ad Malware that is an green underscore and a circle arrow. I cannot find a solution anywhere. AVG has no proper contact address to communicate with. Is it a case of I pay them for next to nothing?
Tim, what did you end up finally doing here?  I've got one of those pop up "offers wizard" just messing with me all the time, inspite of AVG Security Suite.  Del
Tim, AVG may not be able to recommend a ad blocker but I can. I use Ad Blocker Plus and it helps quel the pop up ads a lot.
https://adblockplus.org/
If you watch movies or television shows online like from CBS, ABC or Fox, remember you might have to disable ABP to get the movie or episode to start, but you can re enable it after it starts.
Tim, you also do not want to try using several different ad blocker programs as they might and probably will fight with each other over control and use of resources. Pick one, try it and if you like it, stay with it.
