AVG Driver Updater Problem
I got the same problem mate.
Hello Arunkumar,
You can find answer to your question together with your another post here https://support.avg.com/answers?id=906b000000056ZZ  Please try keep whole conversation in one question/thread to speed up resolution. Thank you.
My AVG Driver Updater is not working properly - It do download the updates - but when it comes to installation of updates - It do not install updates - all the times it shows unspecified error - in all updates it shows the same results - I am not able to install even single updates for which I have purchase this Do it Itself software - Even AVG also keep on sending me pop up message to update drivers - I am helpless can anybody help me to solve this issue.
Hello,
We regret for the inconvenience caused. We would request you to provide the order reference or Invoice number to locate your account and assist you further. Thank you
Arunkumar, In future please refrain from carrying out multiple topic postings on basically the same subject! You won't obtain an answer to your query any faster!.
Hello Arunkumar,
