Avg - ethernet cable - xbox
Hi, i appreciate you getting back to me,
However, I think you misunderstood my problem. Once i try to start a mobile hotspot on my win11 with an "AVG-affected" connection, I can connect but remain with no internet connection. The same goes for my android as well as Xbox one.
Thanks for your time, Tom.
So, I cannot put my vpn on the xbox. Understandable. But why is it that most vpns can be streamed through win11 mobile hotspot or the router and only AVG vpn cannot?
Hey guys,
I've been trying to share my avg vpn to my xbox (since there was a problem with gta online and worked on another pc with a vpn so i decided to get one too). I have watched videos and attempting to share my vpn network from windows 11 to xbox one using an ethernet cable. After failing too many times i have ended up here. Would any of you guys be able to take me through the steps how to add the avg vpn (ultimate) to my xbox one s?
Thank you!
Hi Tom,
You've reached the AVG Community support forum.
We've escalated your concern to our higher level of support. Once we receive an update from them, we'll write back to you over this post.
Meanwhile, your patience is very much appreciated.
Thank you for understanding in advance!
Hello Tom,
We understand that you wish to install AVG Secure VPN on XBOX.
AVG secure VPN can be only installed on Windows, Mac, Android and iOS devices. As XBOX has a custom OS, our AVG software is not compatible with it. We are sorry to inform you that AVG Secure VPN can not be installed on XBOX. Hope you understand our limitations. Thank you.
Hello Tom,
Hi Tom,
And if that would not be possible, is AVG able to be connected directly to my router?
Thank you for writing us back, Tom.
Hey Tom,
My name is Jovana and I'm with AVG senior support. Thank you for reaching out.
While the functionality you mentioned is becoming more popular in the industry, for the time being, we are not planning on implementing it.
Still, we do appreciate your feedback, and I'll surely share it with the team, as we are always trying to improve our services.  I'm glad you shared your point of view on this subject, and I assure you that we will continue to do our best to make advancements.
Hope this clarifies. Let us know if you need any other help.
Take care!
- Jovana
AVG Secure VPN can only be installed on Windows, Mac, Android, or iOS.
XBOX One has a custom OS, and our software is not compatible with it.
Hence you can't install it on the router also.
For further queries, feel free to write back to us.
Our pleasure, Tom.
We'd like to clarify that the protection over a network from a device can't be shared with another device. In order to protect the device, we may need to install the program on the respective device.
Currently Secure VPN is compatible with Windows, MAC, Android & iOS.
