When I attempt to use the D-Link Air Bridge (It is really a wifi 6 adapter) to connect to the Oculus/Meta software on my pc from the Quest 2 headset I can connect to the Air Bridge itself but not to the Oculus software (So I can wirelessly stream the pc games to the headset) unless I disable AVG from the notification area icon. It doesn't appear to create a wifi network that I can change to private to attempt to see if that would help. Is there some way to fix this issue as I have been searching online and have found nothing.
So, just disableing the firewall allows the headset to connect. (Re-enabled after) The network created by the Air Bridge click right back to public within 1/2 second of being set private… so I connected my computer's wifi to it and set it as a private network. The network is listed twice now in the list but the connection with the headset to the pc now works without issue. I guess it is a win lol
Hi Bill,
Initially, please disable AVG Firewall alone to check (Open AVG Internet Security - Menu - Settings - Basic protection - Firewall - click on toggle bar beside it).
If it fixes the issue, then please re-enable AVG Firewall & manage the networks to check if it helps.
(Open AVG - Web & Email - click on 'Open' Firewall - Select Networks tab - click on show settings beside the respective network & set it as trusted network - private).
You can also refer this article to get a better clarity on Firewall options.
Hello Bill,
Its good to know that you have managed to resolve the issue. If you need any further help with AVG, feel free to contact us at anytime. Have a great day!!!
