AVG firewall blocks transmission from PC to TV
Hello !
I'm trying to connect my LG TV with a computer so I can send pictures and videos on the TV, on the other hand, share the PC Connect screen itself. This is obviously caused by the AVG Firewall component. If I uninstall I'm OK. All edits in the firewall settings do not help. I have it uninstalled.
I do not understand the problem at all, but from those hours spent with the problem I guess the transmission works via DLNA and WiFi direct.
Images show the status after successful installation of the device.
The TV is called MojeLG. In the registers, the LG Electronics chain is in the reg1,2,3,4,5,6. The MojeLG string is located in WiFi1 and 2. I do not know if it would be a rule, but it is at my horizon.
Thanks in advance for your help!
Regards !
J. Valenta
images
Hello Jiri,
We realize the situation and let us check by changing the network profile in AVG Firewall.
Open AVG Internet Security program interface.
Click on "Menu–>Settings–>Components–>Customize" of Enhanced Firewall.
Click on "Network Profiles" and if it was set to "public", click and change it to "private".
Check the status with the LG TV and keep us informed about it.
