AVG firewall Causing Problems with Mullvad VPN Working
Hi Vijay,
We're glad to help you with this.
From your description, it seems that the programs need to be allowed by AVG Firewall, in order to access the internet.
In this regard, you can try creating an application rule for the specific program & check if it helps.
Hi AVG Community,                                                               25/10/2020
I have recently purchased a Swedish VPN service Mullvad. However, it is unable to secure my connection as I get a message that my security software has a problem. The original block reason reason: Failed to apply firewall rules. Can anyone please help me with sorting out AVG firewall so that I can use Mullvad VPN?. Thanks in advance.
Thanks and regards
Vijay PAtel
Hi Vijay,
